Activity Forums Adobe After Effects after effects project output question
  • after effects project output question
    Posted by Zach Blumstein on July 28, 2008 at 10:23 pm
    Hello i have to do a project for a client and they want to be able to use the animation on the web, dvd’s, tv etc.. how should
    i approach dealing with all the different size and compression settings
    so that it will work in all these different mediums
    or should i just build it one way and then alter the settings as needed?
    thanks
    zach
    Brendan Coots replied 18 years, 1 month ago 3 Members · 2 Replies
  • Tom Hepburn
    July 28, 2008 at 11:55 pm
    I’d say it’s kind of a personal preference. I like to create my own. For example for company “A”, I would have render settings template called “web_company_A,” or “HD_company_A,” and so on. Obviously each one of those would have the corresponding parameters like resolution, compression if any, format, and so on. Then when it’s time to render I just use the drop down preset in the render module.
    You can create new output module and render settings under Edit>Templates.
    Tom
  • Brendan Coots
    July 29, 2008 at 12:37 am
    The most common method is to design for your largest or most complex need and go from there. For example, the Standard Definition DVD spec calls for 720×480 video, nothing else will do. Based on this, you should probably design your project at 720×480.
    Once the project has been approved, output your 720×480 video to the Animation codec to use as your master. From this file you can create every file you need to deliver. Your DVD authoring software will create all the necessary files from this Animation codec master, and you can use Quicktime Pro or a free program like Super C (scroll to bottom of page for download link) to encode the video to various web/other formats as needed.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
