Activity › Forums › Adobe After Effects Expressions › After Effects position expression
  • After Effects position expression
    Posted by Mahmoud Awd on March 9, 2020 at 5:04 am
    Hey,
    Now I have simple Duik bones for two layers, I separate the values of the position for each, I wanna when y for one move the x for another move!
    When I try the simple parenting the value change for the other value, Any hellp?
    Tomas Bumbulevičius replied 6 years, 5 months ago 2 Members · 1 Reply
  • Tomas Bumbulevičius
    April 4, 2020 at 10:06 am
    Hey Mahmoud, what you need to do:
    1. Alt+click on a stopwatch for x value;
    2. Firstly drag pick whip to x’s value;
    3. Then add ‘+’ or ‘-‘ (depending whether you want to invert position or keep it the same) and pick whip to Y.
    4. Change X position to the original placement you want it to be at.
    Now, by changing ‘y’ you will be directly affecting ‘x’. If you want it to be less/more affective, multiply or divide result of ‘x’ position by a number and you are good to go !
    Find out more:
    Motion Graphics Design & After Effects Tutorials
    On YT
    On VH
