Activity Forums Adobe After Effects after effects + pftrack question why is my object moving but nulls are still
  • after effects + pftrack question why is my object moving but nulls are still
    Posted by Hanna Dean on April 20, 2016 at 8:38 am
    let me break it down quick what i have done.
    1: rendered mp4 to jpeg sequence from after effects.
    2: made solid track in pftrack and exported selected tags to .ma
    3: imported .ma with jpeg sequence.
    now when i insert an image or text i make it 3d layer then try to move it freely ,once in position were i want i use pick wip to assign to null object , some how sometimes my object moves as i scroll threw the shot but my nulls remaian still , whats wrong.
    second wiered problem fps in pftrack
    after effects detects footage original fps 29.97
    when i import the footage , then i go to edit format , i set my fps there matching after effects how ever once i export the tracking data .ma for after effects , the fps sets out to be wrong which is 30.fps or other numbers not matching original fps.
    how do i fix this please help
    Hanna Dean replied 10 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
