Activity › Forums › Avid Media Composer › After Effects output via the Adrenaline box
  • After Effects output via the Adrenaline box
    Posted by David Schwenk on September 16, 2008 at 3:14 pm
    I am looking for the name of the intaller that is packaged with Avid Media Composer 3.0 which allows you to view your After Effects output on the NTSC monitor hooked up to your adrenaline box.
    I am on a PC system.
    Thanks.
    Michael Hancock replied 18 years ago 2 Members · 1 Reply
  • Michael Hancock
    September 16, 2008 at 3:45 pm
    Avid EMP, or AfterEffects EMP (can’t remember exactly which). EMP is External Monitor Preview.
    It should be on the Avid install disc (or available as an install option when you run the installer, if you downloaded it).
    Michael
