After Effects Output Module h.264 ‘settings mismatch’ problem.
Hi all
I’ve been searching for hours literally on this and trying different settings and can’t seem to figure this out.
I’m in AE CS5 and I’ve been attempting to export a 1620×1080 composition size timelapse made from 1620×1080 (3:2) stills.
The preliminary attempt with 1080×720 stills in a 1080×720 (3:2) worked, Output Module Format: H264, resulting filesize, around 7mb.
When I try to do the 1620×1080 version, the exclamation mark comes up about a settings mismatch- Output files will be resized from 1620×1080 (1.00 PAR) to 720 x 1080 (2.00 PAR). That is 720 x 1080, not 1080 x 720.
I tried doing a Output Module Quicktime, H.264, and that produced a file, but it was 220mb. Also, I don’t really understand how that didn’t yield an error also.
I tried also doing H.264, clearing the settings mismatch by clicking resize and setting it to 1080:720 and it rendered a file, which wouldn’t play, Quicktime saying it was possibly damaged. I tried repeating this several times to make sure it wasn’t a faulty render, but it kept repeating this error.
I tried doing a lossless Output and then using Adobe Media Encoder (which for the time being, I would rather not use to simplify workflow), that yielded a file as well, but also relatively large, or letterboxing the output using one of the presets.
The timelapse is only 30 seconds long, so 200+mb is a bit impractical.
Bottom line, I’m trying to understand what I need to rectify in the Output module under H.264 or in composition ‘x:y’ settings in a 3:2 ratio (as the files from my DSLR are natively 3:2, not 16:9) bigger than 1080×720 to resolve the settings mismatch. Or how to get 1620:1080 to work as it has 1080 lines of horizontal resolution, which is also desirable.
Any insight, feedback and assistance would be tremendously appreciated. Thank you!
Ryan
ps. Happy holidays!
