Activity › Forums › Adobe After Effects › After Effects Output Error
Posted by Kingsley Asumadu on January 10, 2015 at 7:58 pmHi Guys.
I’m having problems trying to render (output) my project.
The project is 40 minutes, it renders about 3/4 and then stops with an error message.
Here is the system I’m running:
iMac OS X 10.9.5
3.4 GHz Intel Core i7
24 GB 1600 MHz DDR3 memory
NVIDIA GForce GTX 680MS 2048 MBHere is an image of the error.
Thank you in advance,
Kingsley.
Kingsley Asumadu replied 11 years, 8 months ago 2 Members · 6 Replies -
Tudor “ted” jelescu
January 10, 2015 at 9:09 pmAre you using the render queue or AME?
Tudor “Ted” Jelescu
Senior VFX Artist -
Tudor “ted” jelescu
January 11, 2015 at 12:28 amAre you using large PSD or other image format files?
Is it a 3d composition and if so, what render engine are you using?
Try using Encoder to render out and make sure you close AE, however, the issue may be caused by a large image file and the render may crash again. One thing to do to isolate the issue is to try to render a small piece of the project around the crash point as still files and then to figure out at what exact point the crash occurs. This way you can see if it happens when a new layer or effect comes in play and go from there.
Tudor “Ted” Jelescu
Senior VFX Artist -
Kingsley Asumadu
January 11, 2015 at 1:17 amThere are no PSD files or 3d composition, they are mainly illustrator files, hd video and some png files.
Also I have rendered around the crash point and it renders fine. As it stops around the 31 minute point I have render the last 9 minutes which includes the crash point and it rendered without any errors.
I thought it may have been running out of memory when it gets to the 31st minute.
And how do I rendere in Encoder from AE?Thanks,
Kingsley.
Tudor “ted” jelescu
January 12, 2015 at 7:18 amHere’s some good info regarding AI files in AE (this may be why it crashes):
https://www.jamesmerry.co.uk/home/?p=388As far as rendering from AME this is where you should start:
https://helpx.adobe.com/after-effects/how-to/ame-export-compositions-cc.htmlTudor “Ted” Jelescu
Senior VFX Artist
