Activity Forums Maxon Cinema 4D After Effects Orientation from C4D
  • After Effects Orientation from C4D
    Posted by Dick Smith on February 2, 2007 at 5:12 pm
    Is there an easy formula for setting the orientation correctly in After effects from c4d 10. When i import my solids/nulls from R10 they are all wacked. If anyone knows a script that can do this, that would be even cooler. Or if you can write a script that will do this i will give you a dollar and a jar of honey.
    Dick Smith replied 19 years, 7 months ago 2 Members · 3 Replies
  • Davesink
    February 2, 2007 at 6:00 pm
    Are you using an External Compositing tag on you objects in C4D? If so, these should come in to AE with nulls assigned to the correct position/rotation of the objects’ axis.
  • Davesink
    February 2, 2007 at 6:03 pm
    I just saw another post a little further down that External Compositing may be a bit flakey in R10. I’m still running 9.6 and everything seems OK there.
  • Dick Smith
    February 2, 2007 at 6:18 pm
    Yeah, I am using the external Compositing tag, and yes it is flaky:(
