Activity Forums Adobe After Effects After Effects or Boris
  • After Effects or Boris
    Posted by Donald Schmidt on June 14, 2009 at 9:16 am
    1st Question is which is the Better Software Program to buy. Boris or After Effects ( i know it depends on what i want to use it for but i would like to get the Most out of a program that i can. i’m a complete beginner ) 2nd question i am thinking of buying a Blu-Ray burner is it Worth the Investment and which is a good Burner/Program to go with ?
    Donald Schmidt replied 17 years, 2 months ago 2 Members · 2 Replies
  • Bob Root
    June 17, 2009 at 1:18 am
    Hi Donald,
    After Effects is the easy answer.
    Boris is mostly recognized for their plug-ins. I did find Boris Blue which is a stand alone program, but it doesn’t come close to the functionality of AE. It also looks like it only runs on a PC (don’t know if you are using a Mac).
    If you have a Mac, you may want to compare After Effects to Apple’s Final Cut Studio Pro. Studio Pro has several applications included in the bundle. Their motion graphics application is called Motion. Again, I think After Effects is the better of these two, but you really do get a nice suite with Studio Pro.
    Definitely check out the system requirements of both these applications before your purchase. I would also recommend downloading trial version of After Effects (unfortunately Studio Pro doesn’t have a trial version as far as I know).
    So… while I’m a huge fan of After Effects, you may get more bang for your buck with all of the applications included in Final Cut Studio Pro. You do need a Mac to run Studio Pro though.
    Hope this helps a little.
    Bob
  • Donald Schmidt
    June 29, 2009 at 4:51 am
    Bob I do have a Mac a Mac-Pro to Be precise. and yes i already took the Plunge and i do have Final Cut Studio.
