Activity Forums Adobe After Effects Expressions After Effects Opacity Reacting to Bass Audio
  • After Effects Opacity Reacting to Bass Audio
    Posted by Mario Pascal on December 22, 2016 at 4:34 pm
    Well i’ve started a music channel on YouTube where i make videos about.. well basically its an audio spectrum reacting to music. But i would like to add a flashing light effects where the flashing only happens when a bass sound is played. All i need is an expression for that to happen, I know how to do the rest. If you could even make a tutorial on youtube and link me to it that would be even better but if I get the expression I’m sure i’ll be able to do the rest
    Dan Ebberts replied 9 years, 8 months ago 2 Members · 5 Replies
  • Dan Ebberts
    December 22, 2016 at 5:11 pm
    The trickiest bit might be isolating the bass, for which I would recommend Sound Keys from Red Giant. Or, if you already have that solved, this might help:
    https://motionscript.com/design-guide/audio-trigger.html
    Dan
  • Mario Pascal
    December 22, 2016 at 5:50 pm
    I have already isolated the bass using Sound Keys, but I want to make the opacity react to it. I tried the expression but it keeps showing “After Effects warning: Class ‘Number’ has no property or method name ‘0’
    Expression disabled.
    Error occurred at line 7.
    Comp: ‘Audio Spectrum’
    Layer: 10 (‘White Solid 2’)
    Property: ‘Opacity’
    Here’s an example of what i want..
    https://youtu.be/10YQXTQZolI?t=10
  • Dan Ebberts
    December 22, 2016 at 5:55 pm
    The expression needs to be modified for whatever property you want to control with it. As written, it will create a wobble when applied to the Scale property.
    Dan
  • Mario Pascal
    December 22, 2016 at 5:58 pm
    Oh.. Well i’m not no expert at this stuff.. so I wouldn’t know how to do this.. If you could show me that would be great if you don’t mind. But it’s ok if you can’t thanks anyway!
  • Dan Ebberts
    December 22, 2016 at 6:11 pm
    If you were doing it with keyframes, how would you do it?
    Dan
