Activity › Forums › Adobe After Effects › After Effects Numeric Fields as a Calculator
Posted by William Saviola on July 11, 2016 at 4:38 pmSince version 2015.3 the calculator when used in numerical fields does not work.
Why have adobe removed this function.
Does anyone know?
William Saviola replied 10 years, 2 months ago 4 Members · 7 Replies -
Walter Soyka
July 11, 2016 at 4:45 pm[William Saviola] “Since version 2015.3 the calculator when used in numerical fields does not work. Why have adobe removed this function. Does anyone know?”
It’s still there and working correctly in 2015.3. Perhaps you should try resetting your preferences? Hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while Ae is starting.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Kevin Camp
July 11, 2016 at 6:10 pmI have noticed the same issue (Ae 13.8, OS X 10.11.5).
It’s seems to be specifically the size attribute (comp size or solid size). layer attributes, like position, scale etc, behave normally.
I did try to rebuild the preference file, but no effect…. I’m thinking it’s just a bug.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Walter Soyka
July 11, 2016 at 7:52 pmWell, how about that. It seems to be any dialog box. I’ve filed a bug report; please consider filing one also.
Walter Soyka
Walter Soyka
July 11, 2016 at 8:56 pm[William Saviola] “how do you file a bug report?”
https://www.adobe.com/products/wishform.html
Walter Soyka
Michael Szalapski
July 12, 2016 at 2:42 pmThe bug only happens in dialog boxes. It still works in properties.
Also, if you press = in the dialog boxes it’ll make it work too (in most cases).– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
