Activity › Forums › Adobe After Effects Expressions › After Effects Nulls from Path
  • Filip Vandueren
    June 20, 2022 at 7:54 am
    Hi Albert, unfortunately expressions can only access the path as it is stored in the original property or keyframe, not how it finally looks after trnsformations such as wiggle paths or zig zag.
    Maybe you can achieve your path design in illustrator, and import it ?
  • Filip Vandueren
    June 20, 2022 at 12:53 pm
    I think I misunderstood, because you used the word “zigzag”, but you didn’t actually add a zigzag modifier ?
    Anyway, I don’t have the problem you do:
    • create a random zig zag shape
    • select the shape Path and run “Create Nulls From Path” -> Points Follow Nulls
    • reposition the Nulls so they now form a straight line.
    • select the Shape again (it now has an expression applied)
    • run “Create Nulls From Path” -> Trace Path
    • The new Null that is created follows the straight line (or whatever I manipulate it in to), not the original zigzag.
    Perhaps your problem can be fixed just by emptying the cache ?
  • Albert Jimenez
    June 21, 2022 at 2:26 am
    Absolutely brilliant! Exactly what I need. I must admit, I spent more hours trying to figure it out how to achieve that and it was always in front of me.
    Thank you Filip
