Activity Forums Adobe After Effects After effects not rendering properly
  • After effects not rendering properly
    Posted by Naresh Ugaonkar on March 5, 2018 at 11:10 am
    I have made a mindmap and I have animated it in after effects using the camera. the whole project looks and works just the way it should inside after effects but when I am rendering it in the media encoder I get a zoomed out render. the zoom level somehow changes when the video is rendering. I have tried cropping the composition to the region of interest, however, there’s no change in the rendered output. I am using a null object to animate the camera which is not visible. I am also using cc Libraries if that has anything to do with it. all layers which should be 3d are 3d.
    I am using the latest version of after effects. I have 8 GB of ram using windows 10 pro using a Nvidia GeForce GT 710
    below are two images first one is the desired output I want and the other one is what is being rendered which as you can see is little zoomed out.
    https://drive.google.com/file/d/1j8ktaNIk7uf7SHmhIXZaBWM8XliwfXBa/view?usp=sharing
    https://drive.google.com/file/d/1nldUWrT1nenAJ3ZVrB5LktFKa4-m7qhk/view?usp=sharing
    Katryna Sleptzoff replied 8 years, 5 months ago 2 Members · 1 Reply
  • Katryna Sleptzoff
    March 5, 2018 at 3:21 pm
    Can you upload a screenshot of your render settings in media encoder before you export?
