Activity Forums Adobe After Effects After Effects not previewing live animation while scrubbing
  • After Effects not previewing live animation while scrubbing
    Posted by Hauck Araujo on September 3, 2010 at 2:44 pm
    Hi guys,
    this is just driving me mad. It happened before in other minor projects, and i finished without it. But, now it’s getting on my nerve.
    For some reason, after effects is not previewing the animation on the timeline while i scrub the playhead.
    When i stop scrubbing, it updates to the frame i released it, but i cannot see anything animating…. If i move frame-by-frame using the keyboard shortcut, i can see. But it’s a pain to check bigger animations…
    the funny thing is, i can see the handles of the selected layer moving while i scrubb.
    I saw a related post suggesting to change the display modes, or turn on and off the OpenGL… tried, didn’t work… also, the color depth, checked, it’s 8bit… ok… same thing…
    anyone has some light for me?
    thanks a lot,
    hauck
    ##trying hard###
    Ranveer Singh replied 6 years, 3 months ago 6 Members · 6 Replies
  • Hauck Araujo
    September 3, 2010 at 4:46 pm
    THAAAAANK YOUUUUUUU!!!!!
    so much ideed!
    ##trying hard###
  • Zina Saunders
    December 16, 2012 at 3:13 pm
    I want to add my own “thank you” to this thread, I was having this problem and am very grateful to this thread for providing the solution.
  • Candace Koller
    January 16, 2014 at 3:31 am
    After toggling on the Live update button, if it is still not working, make sure your Caps Lock is not turned on. I had the same problem, once I turned off the Caps Lock it was able to refresh.
  • Tim Donderevo
    January 11, 2016 at 6:27 pm
    Thanks for the CAPS LOCK tip – in After Effects CC I had to toggle the ‘Live Update’ check mark a few times, then turn CAPS LOCK on and off a few times and toggle the check mark a few more times before it started working in AE.
    There’s definitely a bug in CC, as Live Update was not working despite being checked in the Timeline Menu and CAPS LOCK being off.
  • Harold Durnez
    June 11, 2020 at 5:19 am
    Any luck here @Hauck?
    I’m having the very same frustrating issue..
  • Ranveer Singh
    June 12, 2020 at 8:54 am
    I don’t know the permanent solution of the problem but you can hold down the Alt key while scrubbing for the preview.
