Activity › Forums › Adobe After Effects › After Effects Memory Usage
  • After Effects Memory Usage
    Posted by Jim Malmstrom on January 2, 2012 at 2:45 pm
    This has been a nagging a question I’ve had: Is the RAM that you assign for AE’s use not available for your OS or other app’s even when you haven’t started AE, when AE is in an “unopened” state?
    Thank you!
    Jim
    Jim Malmstrom replied 14 years, 8 months ago 2 Members · 2 Replies
  • Darby Edelen
    January 2, 2012 at 6:37 pm
    [Jim Malmstrom] “This has been a nagging a question I’ve had: Is the RAM that you assign for AE’s use not available for your OS or other app’s even when you haven’t started AE, when AE is in an “unopened” state?”
    No. AE should only reserve RAM for itself when it is open. When you quit AE it should release the RAM for usage by other applications and your OS.
    Sometimes if AE crashes, or you have to force quit, the additional rendering processes used for “Render Multiple Frames Simultaneously” may remain open. You can check this in Applications > Utilities > Activity Monitor on OS X, or in the Processes section of the Task Manager on Windows. If instances of “aeselflink” are still running you may want to kill them.
    Darby Edelen
  • Jim Malmstrom
    January 2, 2012 at 7:05 pm
    Thank you!
