Activity Forums Adobe After Effects After Effects Matte Ghost in Animation
  • After Effects Matte Ghost in Animation
    Posted by Andrew Wagstaff on October 11, 2016 at 11:02 pm
    Im having a issue with a composition im putting together a shot in Cinema 4D that has alot of charcters in, so ive done it in layers but take a look at the rendered video below and you’ll see flickering and ghost images, ive checked the render of each layer both the image and the alpha layer frame by frame and there is nothing out of place and it only happens when the layers are in the same composition
    https://www.youtube.com/edit?o=U&video_id=wpYFHPe5vNY
    Does anyone have any ideas why this is happening and how i can fix it?
    Andrew
    Andrew Wagstaff replied 9 years, 10 months ago 2 Members · 4 Replies
  • Roei Tzoref
    October 11, 2016 at 11:10 pm
    you should probably post your question here: https://forums.creativecow.net/cinema4d
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Andrew Wagstaff
    October 11, 2016 at 11:16 pm
    surely its an issue with after effects since nothing shows up into all the clips are in after effects
  • Roei Tzoref
    October 11, 2016 at 11:45 pm
    I see. you mean in Cinema 4d all is fine but in Ae it messes it up? please share a screenshot of your full Ae interface with the maxon cineware effect in the effects controls in full view so we may look at your settings.
    Roei Tzoref
  • Andrew Wagstaff
    October 12, 2016 at 2:43 pm
    The way i went about setting up the composition was to animate each layer separately so i have each layer except the background has a alpha layer i rendered each as a picture sequence then put them together using quicktime pro i then put each video into the composition and used each layers track matte using the luma setting
    the ghosting doesn’t show up when using the alpha setting thats why i assumed the layers were interacting with each other in a
    weird way
