Activity › Forums › Adobe After Effects › After Effects mask not revealing the layer below?
  • After Effects mask not revealing the layer below?
    Posted by Jordan Davies on July 26, 2016 at 8:44 am
    I’m working my way through a project and leave it for the night. When I come back the mask I was using as a cut is no longer working. The layer below should be being revealed but it just isn’t anymore? Have I hit something by mistake? See image:
    Daniel Waldron replied 10 years, 1 month ago 4 Members · 6 Replies
  • Walter Soyka
    July 26, 2016 at 5:59 pm
    I don’t see any track mattes, but have you perhaps applied an effect to that layer that is ignoring the masks?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kalleheikki Kannisto
    July 26, 2016 at 6:05 pm
    As far as I can tell, the selected mask covers the entire layer and is set to add, which means that this mask is not set to reveal or cut anything out.
  • Jordan Davies
    July 26, 2016 at 6:48 pm
    The white space behind the car should be revealing the layer below, you can see the time indicator showing its over the 2 layers. No mattes or anything applied. It was fine yesterday and opened it up today and it’s lik this. Strange!
  • Daniel Waldron
    July 26, 2016 at 7:22 pm
    I see the mask on your layer, but I don’t see outline of the mask in your composition window. Are you sure it’s path didn’t get changed to something larger than your footage?
  • Jordan Davies
    July 26, 2016 at 7:32 pm
    Yeh I just hadn’t the mask selected when I took the screenshot. You can see the shape of the mask in the white space to the right of the frame.
  • Daniel Waldron
    July 26, 2016 at 9:07 pm
    Ah I see. What happens if you solo the bottom layer?
