Activity › Forums › Adobe After Effects › After Effects Macros?
  • After Effects Macros?
    Posted by Jaxson on December 11, 2006 at 7:19 pm
    Good afternoon everyone. I am working on a project with about 40 or so separate drawings, each one containing anywhere between 30 to 40 layers that need the same treatment.
    For each layer of each drawing I am currently:
    1.Importing the drawing
    2.Pre-comping each layer
    3.Tracing over the strokes with the pen tool to create a mask
    4.selecting all of the layers in the particular drawing and setting the write-on effect, to reveal each stroke.
    5.Copying the mask coordinates, and pasting them to the Write-on Brush position.
    This is allowing me to achieve the desired results, yet the tracing process and the copying of the mask and pasting to the write-on brush position are very time consuming. I’m thinking there is probably no easy way to get around the tracing bit, but I feel like there must be a better way to do the copy mask shape and paste to write-on brush position. Macros ,expressions, any work flow help you can give would be appreciated.
    Thanks.
    Mylenium replied 19 years, 9 months ago 2 Members · 1 Reply
  • Mylenium
    December 12, 2006 at 10:48 am
    You are looking for an easy solution where there is none.
    Mylenium
    [Pour Myl
