Activity Forums Adobe Encore DVD After Effects looping menu shows black frame
  • After Effects looping menu shows black frame
    Posted by Lichai Cohn on January 6, 2009 at 9:12 pm
    Hi everybody,
    First of all let me thank you for the great tutorials, they really helped me a lot!
    I’ve created a movie in Premiere CS4 and exported it to Encore CS4 through Dynamic Link. Next I’ve imported an After Effects CS4 Composition, again through Dynamic Link. Next I’ve set up the DVD exactly the way I liked with the AE-comp as a looping background for my menu. I’m quite new to both After Effects and Encore.
    Everything works exactly as I hoped except for one thing. The looping background shows one black frame after (or perhaps before) every loop. After Effects uses the complete timeline. I’ve also tried to set the duration of the video in the Menu Motion properties in Encore one frame less, but it didn’t work. I also tried rendering from After Effects and importing, but the same happens.
    I’m not sure whether I’m doing something wrong in After Effects or Encore, but because when previewing in After Effects I don’t see the black frame I assumed it was Encore.
    Thanks for any help in advance!
    Gianni Salvador replied 14 years, 5 months ago 4 Members · 21 Replies
  • 21 Replies
  • Jeff Bellune
    January 7, 2009 at 2:32 am
    Burn a test RW disc and test it in a hardware and/or software DVD player. Encore’s preview is usually slower than “real” DVD players when menus loop, timelines change, etc.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Lichai Cohn
    January 7, 2009 at 9:45 am
    Thanks, but I already tried that. I have built the DVD and tried playing it back in VLC. I also burnt it and tried on a regular DVD-player, but both show that one frame black.
  • Jeff Bellune
    January 7, 2009 at 12:52 pm
    Double-check the start/end frames of the footage in the AE composition, the composition length and the length of the work area. The work area won’t affect the length of the comp in Encore, but it will affect the RAM preview in AE.
    -Jeff
  • Lichai Cohn
    January 7, 2009 at 7:08 pm
    Thanks for your help again.
    The Comp is 5 seconds long, however, when using the Page Down key to move one frame ahead to exactly 5 seconds (because I can’t seem to drag the CTI to exactly 5 seconds in time), I see a grey frame. I tried shortening the work area and trimming the Comp accordingly, but again the last frame is grey. In one of the tutorials here (on looping particles) I heard that a 5 sec Comp will go untill 4sec 24frames (PAL) because the first frame starts at 0sec. Is this where the problem is?
    The footage is actually some Photoshop-layers with an animating mask uncovering parts of the layers.
    I also tried creating a timeline from the After Effects file in Encore but when trimming the last frame off, the new last frame will be black aswell.
    So it seems everything always ends with one black frame, what am I doing wrong?
  • Jeff Bellune
    January 7, 2009 at 7:20 pm
    Is the last frame in the AE comp black? Or is it grey? This is important because black means that you have run out of footage. Grey means that you have navigated the cursor past the end of the comp.
    The tutorial is correct; a five-second PAL comp runs from time 00:00 to time 4:24. This does not affect the rendered length of the comp it will still be 5 seconds) – it only affects the timecode display in the comp.
    So what color is the frame at time 4:24?
    -Jeff
  • Lichai Cohn
    January 7, 2009 at 7:50 pm
    Thanks again.
    In After Effects the last frame is grey, so I guess it’s just the CTI moving past the work area.
    In Encore the frame is black.
  • Jeff Bellune
    January 7, 2009 at 8:10 pm
    This seems to require some more troubleshooting in After Effects. Can you post links to the AE project file and the Photoshop file/layers? I understand completely if there are client privacy issues that would prevent that.
    However, without the AE project, I’m just flying blind and can only guess at what might be wrong.
    -Jeff
  • Lichai Cohn
    January 7, 2009 at 8:30 pm
    I’ve uploaded the files here:
    AE-project
    PS-file
    I’ve removed one layer from both files containing names of other people who worked with me on this (school)project. Those layers where static so I guess it shouldn’t make a difference.
    Thanks again!
  • Jeff Bellune
    January 7, 2009 at 10:10 pm
    I dynamically-linked the AE comp to a PAL Encore project, and then set the comp as the motion background for the menu. Encore’s preview played it perfectly with no black frame.
    I did not build the project nor burn it to disc.
    If you have rendered the motion menu and then adjusted the length of the menu, Encore may be using the old rendered file version for preview and build. Try moving one or more buttons on the menu, re-rendering, and then moving the buttons back (move, don’t undo) and rendering again.
    Do you have audio for the menu? What is its length compared to the video?
    -Jeff
  • Lichai Cohn
    January 8, 2009 at 11:58 am
    I just created a new Encoreproject to test the same two files with nothing else in the project. Here’s my steps:
    I opened Encore (in the original I started by sending a project from Premiere to Encore) and started a new PAL DVD project without being able to change any other settings (all greyed out, but they were fine: 720*576, MPEG-2, 25 fps, Lower field first).
    I right clicked in the project panel and hit import as menu and selected the PSD file.
    I went to Adobe Dynamic Link -> Import After Effects Composition and selected the aep-file and the correct composition afterwards (menu_bg, there’s also a second version: def_menu, which I used to just paste a lot of copies of the menu_bg composition after another in case I can’t get this to work correctly for this project).
    I double clicked the menu and from the Motion-tab I pickwhipped the Dynamic Linked After Effects composition from the video field.
    Finally I right clicked on the menu and clicked Preview from here. Next I hit the button render currect motion menu or slideshow. 125 frames were rendered in about 10 seconds and the preview started.
    And yet again I get that black frame. This is so frustrating…
    I don’t use audio for the menu.
Page 1 of 3
