Activity › Forums › Adobe After Effects › after effects line glitch
  • after effects line glitch
    Posted by Angela Herr on July 30, 2015 at 8:02 pm
    After doing a green screen replacement on After Effects I ended up with two line glitches where a line of the top layer is cut out on one frame. This has happened a few times before and I am not sure what is causing it or how to avoid it.
    Angela Herr replied 11 years, 1 month ago 53,464 Members · 1 Reply
  • Angela Herr
    July 30, 2015 at 8:22 pm
    My footage is already in Prores 422. Will purging the cache fix the problem? Or are you suggesting that that is the cause of the problem?
