Activity Forums Adobe After Effects After Effects lighting problem.
  • After Effects lighting problem.
    Posted by Alex Handy on January 30, 2013 at 3:11 am
    Hey,
    So I’ve recently been trying to use lights in after effects, and have ran into a problem. When I set my layers to 3D, and add a light to the scene, the 3d layers go completely black. I have found no way to fix this, despite my best efforts.
    I have searched all over the internet, and have yet to find a helpful result. I have double checked to ensure that:
  • Draft 3D is off.
  • My materials are set to receive light.
    Nothing has worked. Please, somebody help!
Andy Jay replied 13 years, 7 months ago 3 Members · 2 Replies
    • Tim Bentley
      January 30, 2013 at 10:51 am
      This probably means your light isn’t pointing at the layers in question, although you haven’t really given us enough information to know. What kind of light is it? If it’s a spot light, you need to point it directly at the surface of a 3D layer – you can set the light’s point of interest by twirling down the light’s ‘transform’ options. Copy one of your layers’ position properties and paste them into the light’s point of interest and see what happens. If nothing, post back with some more information (light type, intensity, screenshots).
      If you don’t want everything to go black when you create the first light, make it a low-ish ambient light, which will evenly light the whole scene. Then you can pick out areas with spot / point / parallel lights.
      Also, you’ll find lighting a lot simpler if you follow some basic tutorials first, or at least read the help page:
      https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103906c6dea-7e29a.html
      I’m not sure there’s actually a problem here – to be honest, everything going black in the scene is exactly what should happen, unless the new light is ambient or happens to be pointing at something in the scene.
    • Andy Jay
      January 30, 2013 at 10:09 pm
      U have exactly the same problem right now, whatever I try to correct, there appears to be nothing wrong. The light either spot or ambient produce the same error, the background has shadows on but the objects casting the shadows are fully black …. not had this before and use light quite a lot.
      MAC OSX
      AE CS5
      If I can sort I will post back, otherwise please help now as I need the lights working for a deadline
      A
