Activity Forums Adobe After Effects After Effects Light Streaks Question
  • After Effects Light Streaks Question
    Posted by Chris Robley on October 16, 2008 at 7:24 pm
    Hey guys,
    Using trapcode particular I was wondering if there is a way to make it so my light streaks taper
    off like this image:
    IMAGE 1
    Currently from the tutorial it looks like this:
    IMAGE 2
    Should I edit the particle layer that is being used or is their some kind of expression or
    option within trapcode?
    Chris
    Chris Robley replied 17 years, 11 months ago 2 Members · 2 Replies
  • Kevin Camp
    October 16, 2008 at 8:03 pm
    under the particle settings, set the size over life graph to start small, increase to full, the taper to small again.
    to make life ease, you can try the 3rd or 4th graph preset, although with a bit of practice you can get really good at drawing the graph…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Chris Robley
    October 16, 2008 at 8:59 pm
    Kevin,
    You are awesome man that worked perfectly thanks so much!
