Activity Forums Adobe After Effects After Effects levels problem
  • After Effects levels problem
    Posted by Mrtvman on February 21, 2006 at 6:15 am
    I’m working in 6.5.1. I just opened it up, applied a levels filter to a solid and instead of the input and output whites being NORMAL (like 0 and 255) they’re both at 32768.0. What’s up with that?! Has anyone encoutered a similar problem?
    Xmithc replied 20 years, 6 months ago 4 Members · 3 Replies
  • Rob Kahn
    February 21, 2006 at 2:01 pm
    I’ve had wierd issues with my RGB inputs (in OSX 10.3.9). What I had to do was toss my preferences file (User>Library>Prefereces>Adobe After Effects 6.5 Prefs). After Effects must be closed when you do this otherwise it will rewrite the existing file when it closes. When you reopen everything will be set back to factory default so any preferences you want will have to be reset. What you could do as insurance is just move and rename the Prefs file as a backup.
    Hope this helps
    Rob
  • Jim Zito
    February 21, 2006 at 3:57 pm
    Check the pull out menu on your info palette. Sounds like you have it set to display decimal instead of percent. It affects the levels display too.
  • Xmithc
    February 22, 2006 at 4:11 pm
    Incidentally, maximum values of 32768 are normal behavior for a 16-bit project (Pro version only). You can change your color depth under Project Settings.
