Activity Forums Adobe After Effects After effects Keying glitch, how do I fix?
  • After effects Keying glitch, how do I fix?
    Posted by Kurt Hudson on October 28, 2009 at 2:26 pm
    Ive been using after effects for 4 years now and been all of my footage on the same camera as well and have never seen this problem before. Everytime I key out my footage and then render I have random glitches appear in my footage COMPLETELY random as in they appear in different places each time I render and not always in the same place. It looks like a line of gain or distortion, like this
    glitch
    glitch
    and I cannot seem to get rid of it… It even does it when I export my footage and its killin me… if someone can help me with this problem please let me know! thanks!
    Roland R. kahlenberg replied 16 years, 11 months ago 5 Members · 12 Replies
  • 12 Replies
  • Roland R. kahlenberg
    October 28, 2009 at 3:47 pm
    It looks like a CODEC issue. You may want to replace one of the footage items again to test if this is correct. Otherwise you’ll have to render multiple times and edit out the bad parts – hopefully the glitches don’t overlap.
    HTH
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Kurt Hudson
    October 28, 2009 at 4:09 pm
    I tried a couple different compressions and still got this issue, its weird because everytime its in different places… I was going to render multiple times and edit out the bad parts as a last resort but I figured that would be one way to solve the problem… have you personally had this issue before? how was it solved?
    October 28, 2009 at 4:31 pm
    The issue is with the CODEC of the source, specifically the decoding part – just a guess on my part. It looks like AE, through the video architecture via the CODEC isn’t able to decode the source footage accurately. The artefacting that you’re seeing is what you normally get with a poorly encoded digital image. I am doubtful that your issues are related to the CODEC that you are rendering with.
    Test the source. Try to redigitize if you can. And nope I haven’t had this issue while keying.
    Good Luck
    RoRK
  • Kurt Hudson
    October 28, 2009 at 4:34 pm
    Hey thanks Dave! Its actually HVX 200 720x24pn (960×720) and im stretching it out to be 1280×720 to be 16:9. I tried using the raw footage as well as sending it thru final cut to be compressed again and im still getting the same problem. Im going to try the animation codec like you said, ill let you know if it helps. Thanks again!
  • Kurt Hudson
    October 28, 2009 at 4:46 pm
    let me know what you need to know, im working on it right now so ill be able to keep you updated. thanks for your help!
  • Tony Silva
    October 28, 2009 at 6:59 pm
    bah, fix it in post! 🙂
    how often does it appear? every frame? once a minute?
    Does it only glitch out on this footage? I would try shooting something else as a quick test, maybe it was a bad transfer from the p2 card?
  • John Cuevas
    October 28, 2009 at 7:02 pm
    Actually had a similiar looking problems years ago, back in the 4.5, 5.0 days. With a much much slower cpu and a lot less RAM. Wasn’t the import footage or codecs, but the computer. Would happen on all sorts of things that involved a lot of processing. New computer solved everything and haven’t had that problem in years.
    Try the “secret” preferences screen(hold shift+cntl when opening preferences). Disable layer cache and turn on purge frames, say every 10 frames.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Ray Crown
    October 28, 2009 at 8:25 pm
    Some Times I user OpenGL render Make problem just like you,and then i switch to Best Setting in after effects,And the result is good,
    Also some sapphire plugin make some noise sometimes,You may need to check which plugin in your after effects,
  • Kurt Hudson
    October 28, 2009 at 8:45 pm
    Ive tried everything it only does it randomly in different places each time i render or ram preview… i might just have to do a few renders and edit out the shitty bits… unless you might be able to help? 🙂
    October 29, 2009 at 7:36 am
    Many thanks to John and Ray for their input. It’s still difficult to pin-point the issue becaue the original poster didn’t see these artefacts during previews. So it’s likely a memor yissue related to rendering/CODEC.
    Hpewfully things get sorted out for now and later.
    Cheers
    RoRK
