Activity Forums Adobe After Effects After Effects is making my text thicker
  • After Effects is making my text thicker
    Posted by Ashley Geiger on November 27, 2018 at 8:12 pm
    Hello,
    I’m trying to animate a graphic that was given to me. The graphic was made in InDesign. When I use the same font in After Effects, it appears slightly thicker than in InDesign. I’ve made sure the stroke is not on. I’m not sure what the problem is. Would love an answer to this as it is driving me crazy.
    Update: I figured out that my bold was turned on. That section of the character window was out of my view so I hadn’t even considered it. Glad I could fix it!
    Max Haller replied 7 years, 9 months ago 3 Members · 2 Replies
  • Andrew Somers
    November 28, 2018 at 10:47 am
    I was about to ask if you were in Linear mode — the anti-aliasing in Linear mode causes text to be rasterized thicker as well.
    Andrew Somers
    VFX & Title Supervisor
    https://www.GeneralTitles.com
  • Max Haller
    November 29, 2018 at 3:38 pm
    I’ve had a few strange issues with using the faux bold and those other text options occasionally. If you run into anything weird with your text later remember to see if that’s causing issues. It normally works fine though!
