Activity Forums Adobe After Effects After effects installation, Harddrives & Rendering
  • After effects installation, Harddrives & Rendering
    Posted by Josh Brine on September 15, 2016 at 4:05 pm
    Hi All,
    Is this the best installation for Creative cloud in terms of speed and rendering
    256SSD w/ Windows & CC installed
    internal 2TB Hard drive, Used to WRITE, (all renders etc will go to this drive)
    Internal 1TB Hard drive used for Cache
    External Raid, RAID5 (connected via USB3) contains all Active and Archived projects, contains all assets etc. (Drobo w/ seagate barracuda)
    My current specs are
    Intel i7 Quad Core Enhanced Performance Processor (4.4 Ghz)
    16GB DDR4-2133 (2 – 8GB DIMMS) (Purchasing 16gigs more ram)
    NVIDIA GeForce GTX 970 4GB
    256GB SSD M.2 PCIe Drive
    2TB 7,200rpm SATA 6Gb/s
    Walter Soyka replied 10 years ago 2 Members · 2 Replies
  • Josh Brine
    September 15, 2016 at 5:44 pm
    good to know thanks.
    im guessing AE will be writing to and reading from the cache for playback etc? so it makes sense to be fast. would 256gb SSD be adequate in your opinion?
  • Walter Soyka
    September 15, 2016 at 9:44 pm
    [Josh Brine] “im guessing AE will be writing to and reading from the cache for playback etc? so it makes sense to be fast. would 256gb SSD be adequate in your opinion?”
    Yes. Faster is better, and bigger is better. The limit is your budget.
    Ae caches not only your final rendered frames, but also the individual renders for each layer in your composite, when caching is faster than re-rendering.
    Consider a 10-layer animation that is 900 (30 seconds at 30 fps) frames long. It will cache 900 rendered frames of the composition, but it can also cache 900 frames for each individual layer for up to 9,900 frames total. Why store so many frames? This way, when you make a change to one of those layers but not the other nine, Ae can read the 9 layers back from the cache to use for the final composite instead of re-rendering them all.
    Additionally, each of these layer-frames is lossless and uncompressed. Fully caching this 10-layer, 30 second animation, at 1920×1080 and 8bpc, would consume about 76 GB of disk space. Of course, as you make tweaks, many more layer-frames will be cached. 256 GB can go pretty quickly.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
