Activity Forums Adobe After Effects After Effects infinite render after painting with clone stamp
  • After Effects infinite render after painting with clone stamp
    Posted by Shaun Rexroat on September 3, 2012 at 6:56 am
    I was clone stamping a frame and I was almost done but suddenly it wouldn’t stop rendering. Just frozen on that frame and rendering for no reason.
    I had to quit through task manager and I saved and when I reopened the file it was till trying to process the paint. It would only stop when I turned off the paint effect.
    What is going on? somehow the paint effect is making the program bug out. Help please. this is so annoying I could punch someone.
    thank
    Shaun Rexroat replied 13 years, 12 months ago 2 Members · 2 Replies
  • Matthew Keane
    September 3, 2012 at 11:47 am
    Do you need the cloning to be animated? If not, you might be better off doing the cloning in Photoshop and bringing the corrected image into AE.
    A few months back I was rendering a fairly simple project that a colleague had prepared and I couldn’t understand why it was taking an eternity to render. When I looked in one of the pre-comps, there were brush effects, with hundreds of strokes – each of which was being rendered during the animation, even though only static images were needed. So I exported the cleaned images as new files, re-imported them into the project and, hey-presto, render time divided by 10!
    The brush effect is great if you need to create an animation of the strokes, but if not, it’s just slowing down your render times.
  • Shaun Rexroat
    September 3, 2012 at 5:48 pm
    I think that’s the problem, but what’s weird is that when I simply deleted the first stroke, the frame rendered in about 5 seconds, which is much better than forever. Also I had about 41 clonestamp strokes and I have a pretty fast machine but I’m also working with HD footage so it must be the amount of strokes like you said.
    thanks for your help!
