Activity Forums Adobe After Effects After Effects help..
  • After Effects help..
    Posted by Adasdj on July 26, 2005 at 10:11 am
    In after effects 6.5 you can make a line with the paintbrush tool.
    I was wondering if that is possible in After Effects 6.0, if not can anyone make a plugin for it, I need this urgent
    thanks in advance
    adasdj
    Aharon Rabinowitz replied 21 years, 1 month ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    July 26, 2005 at 11:01 pm
    I think there was an effect called Vector paint in AE 6.0. It was hard to use, but look for it.
    You could also create a mask/path in the shape of the line you need, and then apply the Render > Stroke effect to the mask/path. You can animate the start and end point of the stroke so that it draws on.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
