Activity › Forums › Adobe After Effects › After Effects Help!! Year Countdown which looks like a flip clock
  • After Effects Help!! Year Countdown which looks like a flip clock
    Posted by Joshprem on June 28, 2007 at 8:56 am
    hi friends,
    i want to make a year countdown for my friends birthday. could you give me any hint how to start with. the numbers have to flip from 2007 to 1954. is there a methode to script this countdown? i added a picture so that you get an idee of what i am talking about.
    thanks in advance…
    Brandon Morris replied 18 years, 10 months ago 4 Members · 4 Replies
  • Rokas Gecas
    June 28, 2007 at 10:51 am
    my advice is to use flash in case you don’t have a good reason to use ae. i don’t think there’s scripting possibilities in after effects because video formats cannot process scripts. i have simple javascript to countdown to selected date. it can simple be transformed into flash action script. let me now if you’re interested in it.
  • Mike Procunier
    June 28, 2007 at 1:09 pm
    If you’re on Mac, Live Type has a font called Flip Count that does exactly what you’re looking for. If not this isn’t too hard in AE. Create 10 Pre-comps, one of each number (0-9) on the card background.
    Duplicate these 10 then use a mask or matte, so that you have a separate comp for the top half and bottom half of each number. Then use card wipe ( columns-1,rows-1, flip direction reversed) to flip from the top half of one number to the bottom half of the next number. Once you have a comp that counts up from 0 to 9 you have the building block fro the rest of your animation.
  • Brandon Morris
    November 6, 2007 at 1:54 pm
    so this would work for an airport departure and arrival sign?
    only… it would require A LOT more precomps, correct?
  • Brandon Morris
