Activity Forums Adobe After Effects After Effects HDV and Audio sync issues
  • After Effects HDV and Audio sync issues
    Posted by Stuartmx on March 29, 2006 at 5:40 pm
    I captured HDV in Premiere as an mpeg, imported into AE, but the audio is all out of sync. It’s in sync on the clip itself, so I know it wasn’t the capture. Is it a GOP issue where I would be better off converting it to an AVI to work with?
    James Purdie replied 18 years, 8 months ago 3 Members · 2 Replies
  • Tim Johnson
    March 29, 2006 at 7:23 pm
    I’ve had some issues with AE 7 using Premiere Pro 2-captured HDV native clips. I ran into all sorts of GOP-related hiccups when using the mpegs w/in AE 7. I now capture HDV in PPro, then render out to another codec within PPro for use in AE.
    Tim Johnson
    KUTV 2 News
    Salt Lake City, UT
  • James Purdie
    January 25, 2008 at 7:03 pm
    Hey there..my audio synch probs with HDV in after effects have driven me crazy. I try to work with the Mpeg2 in AFX and it sucked. Are you saying that buy converting those audio synch issues disappeared? I sure hope so.
    You recommend avi? In AFX I turned my mpeg2 into a jpeg sequence..but the corresponding audio file was still out of synch. I will try to conver to AVI in PP2 and see if stays in sync in AFX.
    Any advice is greatly appreciated!!
    -James
