Activity Forums Adobe After Effects After effects has stopped working when starting
  • After effects has stopped working when starting
    Posted by Christopher Carlsson on April 12, 2008 at 9:15 am
    Hello. When I was going to start my After effects CS3 this morning, I got an error direcly when it started. “After effects has stopped working”, it happens when it’s initializing media core. So, I installed AE 7.0, same thing there. Can’t figure out whats wrong :S It worked just last night, but now, it wont start… Do anyone know what’s wrong?
    Thanks in advance!
    Jack Watts replied 18 years, 5 months ago 2 Members · 1 Reply
  • Jack Watts
    April 13, 2008 at 2:22 am
    It could be that a library or runtime file has been corrupted those are the files that have the extension .dll(dynamic link library) They are the files that after effects will look for and rely on when starting up or when performing a particular task. Its the same with any present day windows based program. Another thing is that there could be an incompatible script or payload on your system conflicting with those that adobe have installed. If you have installed anything on your system in the past few days remove it and do a registry clean.Also if you had a beta version of AE or any other adobe cs3 product on your system or still on your system then their relevant scripts could also be interfering.If the problem is still persisting may i suggest that you run Adobe CS3Clean Script. Once you ahve done that re-install the program. if the problem then still persists contact Adobe Technical Support
    I hope this helps you in some way!
    Kind Regards,
    Jack
