Activity › Forums › Adobe After Effects › After Effects – Hard Drives – Cache
Posted by Gavin Williams on September 30, 2012 at 8:50 amHi
I am starting to work with After Effects and am concerned with the warning about my Cache Disk and scratch disk every time I open the application.
The default obviously puts the cache disks on my MAC HD. Is there something I should be doing to avoid the warning and make AE work better?
I do have a rugged Lacie drive with FIREWIRE connection – could I incorporate this into the set up?
Any assistance would be greatly appreciated!
Todd Kopriva replied 13 years, 11 months ago 4 Members · 7 Replies -
Vishesh Arora
September 30, 2012 at 11:38 amMr. Williams
Using Lacie for Disk Cache will be a good option. This will remove the irking warning and provide you more space on your Mac Drive. Also clear ” Database and Cache” on regular interval to remove old cache if your drive is out of memory.
Vishesh Arora
VFX and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Gavin Williams
September 30, 2012 at 1:39 pmHi Vishesh
Thanks so much for coming back to me on this
So should I put both caches onto the Lacie – the disk and media that it mentions?
Also I am running Premiere CS6 and importing the projects into AE – should I therefore put Premiere folders on the Lacie too? If so would that be the footage?
Gavin
Walter Soyka
September 30, 2012 at 2:49 pmCan you describe a bit about your computer system, the video formats you use, and the sorts of Ae work you’re going to be doing?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Gavin Williams
September 30, 2012 at 3:53 pmHi Walter
I am running on iMac 2.7GHz Interl Core i5 with 12GB memory 1333 MHZ DDR3
I have a firewire Lacie 1TB external
Basically I am using AE for titles, basic effects and grading – I have just moved to Premiere from Final Cut so it will be working with Premiere Pro Projects. So it would be handy to know the most efficient way to run these two programs (ie where to store the cache, the footage etc etc_)
Thanks Walter
Gavin
Walter Soyka
September 30, 2012 at 4:03 pmDisk speed is very important for performance, and neither the iMac’s internal HD nor a Firewire-attached disk are high-performance options.
Do you have one of the Thunderbolt iMacs? You’d get the best performance for your configuration from a Thunderbolt-attached RAID.
If not, I’d probably keep footage/scratch on the external drive, but I’d consider putting the Ae cache on the system drive.
Walter Soyka
Gavin Williams
September 30, 2012 at 4:07 pmGreat – thanks Walter
Yes the IMac does have a thunderbolt connection – can you recommend a cheap drive at all? Will I then store everything on this new drive? (All caches, footage etc)
Gavin
Todd Kopriva
October 1, 2012 at 2:39 pmHeed Walter’s recommendations. The After Effects cache is best placed on the fastest drive with the fastest connection. An external drive connected over FireWire is a terrible place for it.
After Effects team blog
