Activity Forums Adobe After Effects After Effects Green Cache Bar
  • After Effects Green Cache Bar
    Posted by Jon Spells on April 19, 2012 at 6:24 am
    When ever I preview by pressing the space bar the process starts like normal. But about 5 sec in down the timeline, the green buffer bar in the timeline start to move from the start. Its like I cant fully cache the process. Here is a pic of what Im talking about
    4002_screenshot20120419at1.20.00am.png.zip
    How can fix this problem. I can no longer watch the entire preview in real time. Just only within the green. Just to let you know, I cant get the bar to cache any larger than that.
    Thanks in advance.
    Todd Kopriva replied 14 years, 4 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    April 19, 2012 at 6:51 am
  • Jon Spells
    April 20, 2012 at 2:05 pm
    That didnt help my situation. When I ram preview with the number pad I am fine. This is only when I use the space bar. Also this happens in PF Track. When I press play the it starts to cache fine then it starts deleting the green cache bar as it moves down the timeline.
    Also I noticed this started when I upgraded to Lion. Could Lion be the problem.
    I hope you understand my garbled up words.
    Thanks in advance
    Jon
  • Tero Ahlfors
    April 20, 2012 at 3:29 pm
    When you press the space bar AE starts caching the frames like in RAM preview. When your RAM is filled up AE will start flushing cached frames from the start so it can continue the caching.
  • Jon Spells
    April 20, 2012 at 3:36 pm
    I fully understand now. But could Lion be the cause of this?? It seems like Lion might be a little Ram Hog. Im running a Mid 2009 MPB 2.66 Duo with 8gb of Ram.
  • Tero Ahlfors
    April 20, 2012 at 3:44 pm
    Check your memory and multiprocessing settings in AE. Maybe it’s not using as much memory as it should.
  • Todd Kopriva
    April 25, 2012 at 6:00 am
    If you want longer RAM previews, turn _off_ Render Multiple Frames Simultaneously multiprocessing. You don’t want the background rendering processes taking up all the RAM if you want to use it to hold rendered frames for RAM preview.
    product manager, professional video software
    After Effects team blog
    Premiere Pro team blog
