After Effects – Gigantic Project Management
Hello!
I don’t know if there is a solution to this, but here it goes.
I am working on a large project with multiple scenes and hundreds of assets. When I began working I had an individual project for each scene, which I worked to completion.
Since I am editing the final movie in after effects (it requires multiple transition effects which I can’t do in any other package) I have had to import all of these separate projects (each individual shot) and placed all the master comps from each project onto the timeline. So, one gigantic project consisting of about twenty other projects, all imported into my project window.
Now, there are minor animation changes to several shots but my workflow has come crashing down to zero because of the gigantic master project I have had to create. I want to work on shot 7, for instance, but I can’t go back and open the Shot 7 project and work from there because any changes I make will not reflect in the master Project since it’s already been imported.
So, my question is, am I doing this wrong? Is there a way to reference other projects in a master project where they will update my changes to these projects if I go back? Re-importing these projects each time has created problems, but is that the only way?
Long question, sorry.
TLDR – I have too many projects in one giga-project.
