Activity Forums Adobe After Effects After Effects ‘forgets’ snapshots
  • After Effects ‘forgets’ snapshots
    Posted by Paul Roper on February 26, 2013 at 12:34 pm
    So…I take a snapshot (shift-F5, shift-F6 etc.). I can view the snapshot (F5). Lovely.
    I do a render. I press F5. No snapshot is stored. Is this normal? It’s a pain in the arse. It’s as if the frame buffer that stores the snapshot(s) gets overwritten during the render process, but I’ve got 64GB RAM – surely there’s a little bit spare to store a snapshot or two?!
    I’ve submitted a bug report to Adobe, but I just wondered if anyone else has noticed this same thing?
    – Paul
    Todd Kopriva replied 13 years, 6 months ago 4 Members · 4 Replies
  • Jim Arco
    February 26, 2013 at 12:44 pm
    I only have CS5.5 on this machine, but it works fine for me. Does it do the same thing if you use the icons on the comp window instead of F5?
    Jim
  • Paul Roper
    February 26, 2013 at 1:33 pm
    Yep – it’s the same if I use the icons at the bottom of the comp window.
  • Ashish Gupta
    February 26, 2013 at 2:50 pm
    Paul,
    i just tried it .. same problem happened ..
  • Todd Kopriva
    March 4, 2013 at 9:42 pm
    This has never worked any differently. I’m looking at the code now, and there is an instruction to purge noncritical RAM contents before rendering, so that rendering can get all of the available resources.
    Jim, I don’t know how you can be seeing any different behavior, since a) the same instruction was in CS5.5 and b) I just tested this on CS5.5.
    If you want this to behave differently, you can submit a feature request:
    https://www.adobe.com/go/wish
    After Effects team blog
