Activity › Forums › Adobe After Effects › After Effects Force Blast
Posted by Cenk Yartan on June 26, 2007 at 10:15 pmI’ve Been Trying To do this effect
Image’s Here
On After Effects.Is this Possible.If It’ll help i can take another screenshoot.
Cenk Yartan replied 19 years, 3 months ago 2 Members · 3 Replies -
Yumology
June 27, 2007 at 12:16 amHi. To get the effect itself, I’m thinking start with a solid, add a ramp, and colorama, and maybe a fractal noise for texture, then add a cc sphere effect. Lay it over the subject, turn opacity down, change mode to add or multiply, make the solid a displacement map for the character.
to learn about displacement maps aharon rabinowitz has a great 3 part displacement map tutorial at https://cowcast.creativecow.net/after_effects/index.html
oh yeah, for the fireblast coming from the character, i think the beam effect will work good, make it nice and thick, you can even adjust the starting vs ending thickness, add a fractal noise to it (so that you can make keyframes in the fractal noise effect to simulate the blast moving, and a texture on the beam will look better), change mode to add. make it a displacement map for the background too.
then animate it. heh
Cenk Yartan
June 27, 2007 at 11:29 amI wonder Which Program used in order to get that effect=Can i rip that effect out of the game and open it with after effects(or another program)and Render It with my video?I mean they must have used a program to get that effect.Is is possible?
Great Power Needs Great Responsibility…UNLESS YOU HAVENT GOT A PILLUSION!!!!:-D
