Activity Forums Adobe After Effects After Effects Final output
  • After Effects Final output
    Posted by Farooq Darwish on October 12, 2011 at 1:44 pm
    Hi guys, i will be glad if someone help here,
    I just create a video song around 3MIN that will be play on TV in Afghani Channels so it is in 59.xx FPS and 1080X920 and i need to export to final format i want good quality and good sound along with it, it was recorded on AVCHD so friends advice me what codec should i choose please tell step by step that i should miss anything
    thank you very much in advance
    FD
    Walter Soyka replied 14 years, 10 months ago 2 Members · 3 Replies
  • Walter Soyka
    October 12, 2011 at 2:12 pm
    Unfortunately, there is no standard answer for this question.
    You have to get the delivery specs from the station that will air it. They will likely have very specific requirements which you must meet.
    Walter Soyka
  • Farooq Darwish
    October 13, 2011 at 3:19 pm
    thanks for reply
    as far as i know they use pal
    and if use 1080p do you think it will work?
  • Walter Soyka
    October 13, 2011 at 7:50 pm
    I think you need to contact the station that will air this and find out what they expect.
    If you are delivering a file, you’ll need file-based specs. You will hopefully get a complete delivery spec, including container format, resolution, frame rate, video codec, video bit rate, audio codec, number of audio channels, and audio depth/sample rate/bit rate. There may be additional requirements on slate, run time, time code, head and tail, audio channel designation, etc.
    Walter Soyka
