Activity › Forums › Adobe After Effects Expressions › After Effects filters
  • After Effects filters
    Posted by Relmansy on October 8, 2006 at 6:12 am
    I would like to enhance my After Effects project with glowing effects. Do any one know a place to find free filters that enable me to create such glowing, sparkle, fire….etc.?
    Thanks alot!!
    Majorasshole replied 19 years, 11 months ago 4 Members · 4 Replies
  • Mylenium
    October 8, 2006 at 3:14 pm
    You must be kidding (no offence). You can certainly find many such effects, but they are not free (you know, a developer has to make a living, too). Check around, from Trapcode’s Starglow to BorisFX to Sapphire there’s several options, but keep your credit card near you. If you don’t have any money, explore AE’s own tools. You can easily create “sparkles” by combing two instances of glow – one horizontal only, one vertical only. Check around here at the COW, you can find many such techniques. I also suggest you study my lensflare tutorial along with the project files, they may contain some tricks and expressions you can use as well. For fire study Dan Ebberts’ particle systems tutorial.
    Mylenium
    [Pour Myl
  • Mike Clasby
    October 8, 2006 at 6:55 pm
    Freebie Plugins Some Glow, some not.
    Freebie plugins are on the wane, Buena Vista’s ee Camera Flash did what Aharon’s tut (Click his head and scroll) “Creating a Film Flash Transition”, but there still are a few freebies around, and some nice ones too. Many of Pete’s Plugins are glow or blur-like, other freebie plugins are; sine dots, ae flame, and more, it takes a little rooting around, start here:
    Forty two freebie Plugins (Kaleidascope and Smear(like Scale Wipe but better parameters) are great)here:
    https://www.petewarden.com/
    Beautiful Fractals here:
    https://www.andrewdavidson.com/aeflame/
    Sinedots, sinedots II, shear and retrodots (cool):
    https://www.philipp-spoeth.de/
    xmult good for compositing:
    https://fandev.com/xmult.html
    also:
    https://www.borisfx.com/download/freebies.php#bcc
    While not a plugin, Scott Frizzle “Quaker” is essential an EarthQuake Plugin, this is a must when you want to shake things up a bit, drop the preset (.ffx into your AE presets folder), preset and pdf here:
    https://www.scottfrizzle.com/free_quake.html
    Scott also has some killer Particular Preset above.
    There were many freebie plugins in older versions of AE Books, I found Canoa Sphere on an old Book CD, and DE Glower, so check into buying old AE book cd’s.
    While not glows, many freebie Explosions/fire/muzzle blast with tuts here:
    https://detonationfilms.com/free_stuff.htm
  • Relmansy
    October 9, 2006 at 6:46 am
    Thanks alot for helping, I will check those tutorial.
  • Majorasshole
    October 13, 2006 at 7:32 am
    after effects is all about technique and not just using a single plugin
    most solutions to anyones desired look or effect are usually a combination of combined techniques to acheive that look or effect not just a plugin that you apply it and tweak a few variables.
    Unless you are purposely trying to recreate a specific effect that is overused and just a plugin (Yes Trapcode Shine, I’m looking at you, you worn out old bar fly)
