Activity Forums Adobe After Effects After Effects field render multi processor issue
  • After Effects field render multi processor issue
    Posted by John Mitchell on July 23, 2010 at 2:52 am
    AE CS5 64bit – there is a bug when rendering out fields using multi processors. Going from an HDTV 1080_25 preset comp to Animation codec (no scaling – output is 1080i25). Have the output dialogue box set to field render UFF. If you turn multiprocessing on to get the benefits of faster render and preview you get a correctly flagged UFF file but checking the file in AE it is actually progressive (well two identical fields in a row – no movement). Do the same render again with Multiprocessing disabled and the target file is created correctly with fields.
    Don’t know if this is a known problem but could see no reference to it on the interweb so thought I’d post it here – HTH some other users and hope Adobe addresses it.
    Michael Szalapski replied 16 years, 2 months ago 2 Members · 1 Reply
  • Michael Szalapski
    July 23, 2010 at 1:15 pm
    [John Mitchell] “hope Adobe addresses it”
    If you want Adobe to address it, I would suggest filing a bug report. They actually do read them and do work based off of them.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
