Activity Forums Adobe After Effects After Effects Eyedropper/Color Picker Not Working
  • After Effects Eyedropper/Color Picker Not Working
    Posted by Zak Stoltz on June 11, 2012 at 10:19 pm
    This is driving me crazy. Any time I’m working with ANY effect, clicking on the color picker doesn’t do anything. Nothing. It’s as though I didn’t click it at all. However if I click on the color swatch next to the color picker and THEN select the color picker from inside that window, it DOES work. I have no idea why this happens.
    I am occasionally able to get the initial color picker to work if I double/triple/14x click on it at lightning speed. But that’s not something I’m interested in doing more than never again.
    Any ideas?
    Bill Carson replied 10 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Roland R. kahlenberg
    June 12, 2012 at 1:29 am
    Which version of AE and which effect’s eyedropper are you using?
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Zak Stoltz
    June 12, 2012 at 1:49 am
    Ah yes. Working with CS5.5 and it’s literally every effect that has a color picker.
    June 12, 2012 at 9:09 am
    That is strange! Not knowing better, my first culprit of choice would be OpenGL. Conduct a little mini investigating to see if such is the case.
    Cheers
    RoRK
  • Zak Stoltz
    June 14, 2012 at 10:42 pm
    Ding ding ding! We have a winner! When I turned off OpenGL at first, it didn’t do anything, but then I restarted my computer and the color picker worked like a charm. Then I turned OpenGL back on, and everything still works. Just had to reset it I guess.
    Thank you Roland!!!
  • Joakim Helger
    November 16, 2012 at 7:30 am
    I found that it was another application (spotify) who made the eyedropper fail. It probably uses openGl in some odd way. Try turn off all other applications if it fails again. I didn’t even have to restart AE, it simply started to work again when Spotify was terminated.
  • Zak Stoltz
    November 19, 2012 at 10:28 pm
    Ahhh. That is very interesting. The problem has been coming back every now and then, and I have definitely had Spotify running in the BG almost constantly since I got it earlier in the year… Will have to keep an eye on that. Thanks for the insight!
  • Wolfgang Purkhauser
    August 17, 2013 at 6:36 pm
    You are a genius 😀
    I was going crazy with this bug for hours now, turned off spotify and the color picker worked again immediately!
    Thanks a lot
  • Bill Carson
    June 10, 2016 at 6:02 pm
    I’m going to follow up many years later. Yes, it’s Spotify for me as well. Shut it down, instantly good to go.
