Activity Forums Adobe After Effects Expressions After Effects Expression – Pro Trick – Multiple Layer Names on 1 Text Layer
  • After Effects Expression – Pro Trick – Multiple Layer Names on 1 Text Layer
    Posted by Roland R. kahlenberg on June 10, 2025 at 7:23 am
    You’ll occasionally have to overlay a layer’s name in your After Effects comp. If you didn’t know better, you’d have 1 Text Layer for each Layer.
    BUTT there’s a better way …
    Apply this to the Source Text Property of a Text Layer –
    // Start of Expression
    let layerNames = “”;
    for (let i = 1; i <= thisComp.numLayers; i++) {
    if (i === index) continue;
    let targetLayer = thisComp.layer(i);
    if (http://targetLayer.active) {
    layerNames += Layer Index:${targetLayer.index} - ${http://targetLayer.name}\r\n;
    layerNames.trim();
    // End of Expression
    If you don’t have overlapping layers, then use the version of the Expression displayed at the end of this video –
    https://youtu.be/JXmoVWsuwUA
    Roland R. kahlenberg replied 1 year, 2 months ago 2 Members · 3 Replies
  • Dan Ebberts
    June 10, 2025 at 7:17 pm
    Roland,
    I’m guessing that some unintentional reformatting occurred when you posted your code. I’m taking a shot at what I think you might have intended here:
    let layerNames = "";
    if (targetLayer.active) {
    layerNames += targetLayer.index + " - " + targetLayer.name + "\r\n";
    layerNames.trim();
  • Dan Ebberts
    June 11, 2025 at 3:24 pm
    Ah, I missed the template literal. So once you change the curly quotes to straight quotes and get rid of the http:// stuff, this should work:
    layerNames += 'Layer Index:${targetLayer.index} - ${targetLayer.name}\r';
    layerNames.trim();
  • Roland R. kahlenberg
    June 11, 2025 at 4:10 pm
    Thanks Dan. I just noticed the strange character insertions and yes, The “http://” insertion was WILD! LOL
    Thanks for tidying it up. 👌
