Activity › Forums › Adobe After Effects › After Effects Exports into Avid
  • After Effects Exports into Avid
    Posted by Martin Banks on May 17, 2005 at 3:12 pm
    I’m trying to import an exported clip from AE into Avid Xpress DV 3.5 but once it’s into Avid the clip changes colour or the quality is terrible. As far as I have checked the settings for AE and Avid are the same, but it’s just not working. Does anyone one else have this problem or know how I can prevent this from happening. Any help would be very helpful!
    Many thanks,
    Martin
    Daniel Garcia robles replied 21 years, 4 months ago 2 Members · 3 Replies
  • Daniel Garcia robles
    May 19, 2005 at 9:24 am
    What codec have you saved your video from AE?
  • Martin Banks
    May 19, 2005 at 10:00 am
    I am using the make movie option to create a QuickTime using the DV-PAL compressor, I’m not sure about the codec, how can I tell?
    May 28, 2005 at 4:05 pm
    You should be able to send your movie to the Render queue and use the Animation codec which is recognized by Avid. The best solution would be to install the Avid DV codec into your system in a way that AE can use it as well for export into Avid.
    Daniel
