Activity › Forums › Adobe After Effects › After Effects Export Problem
  • After Effects Export Problem
    Posted by Aaron Kilcoyne on March 16, 2010 at 10:23 pm
    Hello,
    I’m somewhat a beginner with Adobe After Affects CS4 and I’m working on a project that demos a website in ~50 seconds. In a nutshell, this video contains screen recordings, voice overs, text, and basic graphics.
    I recorded all of the screen movement with Camtasia and saved them to the .avi file format. Please note, these files are video only.
    I recorded all of the voice overs with Audacity and saved them to the .wav file format. These files are at the following settings: 44.100kHz, 16-Bit, and Mono channel.
    No matter what format I export to, the audio starts cracking bad and begins to sound like something from Transformers. I have tried this process multiple times, trying a variety of settings.
    I then exported the composition without audio as a .mov file and put it into a new project. In this new project, I imported the voice overs and put them at the correct position. When I export this now, it works flawlessly and sounds great!
    These projects are basically similar though!
    What could be the reason for the original project/method not working?
    This is really puzzling me, any suggestions would be great!
    Aaron Kilcoyne replied 16 years, 6 months ago 2 Members · 2 Replies
  • Scott Roberts
    March 17, 2010 at 5:26 am
    Do not export, use the render que. Choose your format, output filename and click render.
    https://www.youtube.com/graphicsdump
    https://www.myr3d.com
  • Aaron Kilcoyne
    March 17, 2010 at 5:45 am
    Yep. I tried both options, export and render queue. However the sound got really distorted only until I performed the second method of rendering the composition without audio and creating a new project and importing the audio assets.
