After Effects Export help
Heres my problem. I have been making a short movie using a Pal DVD Cam. I am using Adobe Premire to edit the movie but adding effects to a few clips in after effect.
But the problem is when i put the movie together the afer effects parts a different to clips that have not gone through after effects.. the quality seems lower.
What im doing is capturing the dv footage using premiere. Any clips that need effcts are imported into after effects. I apply my effects then export using DVPALPro ( i have also tried uncompressed and still the same). i then just 25 FPS and interlaced.
Can anyone give me any advice to improve my results.
Thanks in advance
