After effects export footage length
Hi guys!
i have rendered 200 frames in 3ds max,
when i export them as a footage to after effecs i have layer 6 seconds length, and when i move marker to the end of the clip after writes that it is ~167 frame.
In composition settings frame rate is setted up to 25 frames per second.
As i understand it must be 8 seconds and 200 frames. So how to fix that? thank you.
