Activity Forums Adobe After Effects After Effects error:overflow converting ratio denominators (17::18)
  • After Effects error:overflow converting ratio denominators (17::18)
    Posted by Imad Abou jaoude on January 10, 2009 at 1:22 pm
    Every time I render a movie I’m geting this error (After Effects error:overflow converting ratio denominators (17::18)) and it happens when prosessing the same frame. It’s not something wrong with this frame because I tried with different video files and I’m always getting this error at exactlly the same frame. My hard disc has enough space, so it is not the problem. What can it be and how I can fix it? Please help me
    Mike Fatum replied 12 years, 5 months ago 7 Members · 6 Replies
  • Joseph Vela
    May 28, 2009 at 5:15 am
    right click video. go to interpret footage. then main. make sure frame rate is exact as composition. problem solved!!!
  • Dave Rice
    October 2, 2009 at 6:23 pm
    It is not solved. Although the process you described will get your footage to work, the length of the footage could change. As an example: I have a .mov file that has a frame rate of 14.99 frames per second, and when I change the interpretation of the footage to ANY number(Even the one the comp already has), it shortens the video length from 59 minutes to 34 with missing footage.
  • Joe Dawson
    October 19, 2009 at 11:21 am
    I had exactly the same problem. I had interpreted the footage, But after I had footage missing? Have you solved this problem?
  • Allan Onderick
    July 22, 2010 at 3:43 am
    Check your plug ins, My issue was from using Video Copilot’s Sure target 2. !
  • Goqor Goqor
    August 16, 2012 at 4:38 pm
    i have the same error After Effects error:overflow converting ratio denominators (17::18) becose some of my clips frame rate was 24.999 and most of them 25 and i fix it by changigng frame rates to 25fps
    i hope it will halp you
  • Mike Fatum
    April 2, 2014 at 8:49 pm
    Hi there-
    I’ve started receiving this error in After Effects CC. If you click “ok”, to make the error message go away, it simply pops back up again. It is impossible to right click on a clip and change the frame rate. I’ve had this problem only with one clip, from a GoPro Hero 3+ Black. All other clips from the same camera don’t cause this problem, and a different section of the same clip only gave me the error once, so your method of fixing it worked. I’m at a loss.
