Activity › Forums › Adobe After Effects › After Effects error TDL??
Posted by Dave Fleming on January 3, 2013 at 7:17 pmI’ve never seen this one before…I created a block in Illustrator and typed some letters to cut out of the block by creating outlines and then making a compound path to cut out the letters.
I brought the file into AE to be used in a ray-traced 3D comp to get some extrusion and environment mapping on it. When creating the outlines from the vector layer, I get:
“After Effects error: TDL: outline contains traingles that are too small to be rendered. Check for very thin triangles in original artwork. (88::3)”
Any ideas?
Dave
Nikhil Patel replied 12 years, 9 months ago 3 Members · 11 Replies -
Ridley Walker
January 3, 2013 at 8:28 pmA couple of things come to mind. When you made the Compound Path did you Expand the resultant shape? If not try that. The shape should be as simple as possible for After Effects.
When you view the Illustrator file in outline view are there any stray points? If so in Illustrator go to Select > Object > Stray Points and delete them.
Dave Fleming
January 3, 2013 at 10:24 pmThanks for the reply, but unfortunately, that isn’t the problem. But, I do have more information about how this error is occuring. The error occurs not when making the shapes from the vector layer – that works OK. But, as soon as I try to make the new outline layer 3D by clicking the 3D box on the layer, I get the error.
To test this further, I created a box in Illustrator. I typed the letter “I” in the box, created outlines for the letter and made a compound path for the cutout shape. So, in other words, the simplest shape I could possibly make that still gives me the look I want. I imported the file to AE, made shapes from the vector layer…OK. Turned the layer into 3D – boom – got the error.
Is this a bug?
Dave
Ridley Walker
January 3, 2013 at 10:48 pmJust did the same thing without any problem. Did you select Expand Appearance from the Object menu before importing into AE?
BTW, I’m on CS6 with all updates.
Dave Fleming
January 4, 2013 at 1:59 amHonestly, I did not try that. I was so disgusted over the whole problem that I quit for the evening. I will give your solution another go tomorrow and let you know what happens. Thanks for the suggestion!
Dave
Dave Fleming
January 4, 2013 at 2:26 amForgot to mention previously, also on CS6 – the whole suite.
The AE comp already utilizes 2 or 3 other Illustrator files converted to shapes from vectors – not like the one I’m trying to make, obviously, but with much more complex shapes than this one.
I’ll start from scratch tomorrow and begin with a simple shape element with a cutout and go from there.
df
Dave Fleming
January 4, 2013 at 10:38 pmRidley,
What I did in the final analysis to get things to work (I’m on a deadline, just like everybody else), was to switch fonts a few times until I fould something that would work. I ended up using Brandon Grotesque instead of Helvetica Neue, which I think we would both agree are pretty similar sans serif fonts. But, for some reason, it likes the one and not the other. I did try “expanding” the shape (expand appearance wasn’t available), but I’m not sure what that did if it did anything. How do you know?
I did have a colleague in another state duplicate my workflow and he got the same result (error at first, then OK when switching fonts), so, in my opinion, that spells B-U-G. Plus, I have multiple other AI objects within the same comp, all with shapes made from vectors – highly complex shapes at that – and AE has no problem with them.
df
Ridley Walker
January 5, 2013 at 12:33 amDave;
That’s really very odd. I’ve just duplicated the process using both Apple’s Helvetica Neue and Adobe’s Helvetica Neue with no issue whatsoever.
I’m running on a Mac using 10.8.2.
I’ve done a screen recording of the workflow I followed, I do use keyboard shortcuts for some steps such as Create Outlines for the Type in Illustrator, see the following:
Ridley Walker
January 5, 2013 at 12:55 am -
Ridley Walker
January 5, 2013 at 1:17 amIt gets weirder.
Just tried this with the same files on another machine and it works fine.
Dave Fleming
January 5, 2013 at 1:58 amThanks for all of your testing. It is very appreciated!
I had sort of suspected early on that having a too small font size would be a problem. So, I stuck to sizes 75 points or larger.
My title word is “EDITORIAL” (in all caps) in a white rectangle. The specific font I was trying to work with is Helvetica Neue Medium Condensed – Heavy at around 100 points. That never worked for me.
I can’t remember all the test fonts I tried, but I remember trying Bank Gothic, which didn’t work. That really sucked, because Helvetica Neue Medium Condensed and Bank Gothic are our two main station fonts.
I tried Adobe Caslon Pro, which worked. My out-of-state buddy suggested than one, since it was an Adobe font! Ironically, it is a heavily serifed font, and so would have more complex shapes than a simple sans serif. Interestingly, Myriad Pro also worked in my system (I’m on a PC). Odd, since that didn’t work on one of your boxes…
But, thank God, I got approval on the Brandon Grotesque version late this afternoon! But, there’s just been so much craziness with this problem that I’m going to submit it as a bug report on Adobe’s site.
Thanks again,
Dave
