Activity Forums Adobe After Effects After Effects error: RAM Preview needs 2 or more frames to playback
  • After Effects error: RAM Preview needs 2 or more frames to playback
    Posted by Joshua Chaulk on July 16, 2014 at 6:42 pm
    I have a Win 7(64-bit) OS
    16 GB RAM
    AE CC 2014
    I am animating some cartoons right now and since i downloaded the new 2014 edition on AE CC i have been getting this error when i work on a comp for a while. It pops up randomly as I’m working at least a couple times a day. The only way I’ve been able to fix it is just by restarting the program.
    Is there something I am doing to cause this or is it just a glitch?
    Ales Dokulil replied 11 years, 11 months ago 3 Members · 3 Replies
  • Kevin Camp
    July 16, 2014 at 7:06 pm
    assuming your not on the last from of the comp, and preview isn’t set to ‘from current time’ you may want to file a bug report:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    when it happens again, you might try edit>purge>all and see if that helps before restarting ae.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Joshua Chaulk
    July 16, 2014 at 8:17 pm
    Thanks Kevin, I’ll try that.
  • Ales Dokulil
    October 6, 2014 at 9:05 am
    I have the same problem (After Effects CC with the latest update)… I already tried all advice but nothing has been solved. What else could I try? I’m a bit desperate
