Activity Forums Adobe After Effects After Effects Error: Opening Sound Component -2166
  • After Effects Error: Opening Sound Component -2166
    Posted by Macbean007 on October 26, 2005 at 12:18 am
    I get this error code, “After Effects Error: Opening Sound Component -2166” when I try to render a simple effect in AF 5.5. Never had it in the past. Does anybody know what this means? Thanks
    Macbean007 replied 20 years, 11 months ago 3 Members · 5 Replies
  • Steve Roberts
    October 26, 2005 at 1:46 am
    Is there an MP3 in the comp? If so, you need to use QT Pro (or similar) to convert the MP3 to WAV or AIFF.
    Steve
  • Ahill
    October 26, 2005 at 1:39 pm
    What version of Quicktime are you using?
    I had this error using AE6 w/QT 7.0.2, reverted to 7.0.1 and no more error message.
    Anyone know if this is fixed with the new 7.0.3 upgrade?
  • Macbean007
    October 26, 2005 at 4:31 pm
    yes, I did upgrade. but how do I go back to 7.0.1?
    thanks
  • Ahill
    October 26, 2005 at 4:41 pm
  • Macbean007
    October 26, 2005 at 7:09 pm
    thanks. i was using 7.0.3 so that version was also causing the problem. there are a few fixes that are posted on the apple web page that help to uninstall 7.0.3 It had to do with using Pacifist. thanks for the clues. fixed the problem.
