Activity Forums Adobe After Effects After Effects Error – invalid ascend count ‘0’
  • After Effects Error – invalid ascend count ‘0’
    Posted by Chris Morgan on September 19, 2013 at 2:01 pm
    I have had an issue with re linking a file into After Effects CC, I can re-import and replace the file in each comp manually but normally I simply reload the file that has been moved from its original location and it automatically updates the links.
    The error displays when trying to reconnect an mp4 video with the correct file name etc, it is the same file nothing has changed After Effects simply won’t re link it, instead it displays the error ‘invalid ascend count ‘0”
    Any takers?
    Cheers in advance !
    Chris
    Chris Morgan replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
