Activity Forums Adobe After Effects After Effects error: creating ADM floater
  • After Effects error: creating ADM floater
    Posted by Dave Tavernier on August 24, 2005 at 7:38 pm
    I can’t get AE 6.5 to start up, I get:
    I re-booted my Mac G5 andI re-installed AE, still a no go.
    Anyone know what this is?
    Jim Wilcox replied 21 years ago 2 Members · 1 Reply
  • Jim Wilcox
    August 25, 2005 at 3:54 pm
    Did you trash your prefs file? This usually has to do with changing the NTSC display prefs and it gets hung up there. If you don’t want to lose all your prefs you can try this: drag your current pref file to the desktop and fire up AE. Quit. Then open up both prefs files (in a text editing program) and search for “[“MacOS Video Preview Pref Section”] in both. If there is a difference copy the section to your existing prefs file (the on causing your Floater) and replace the newer version with your modified orginal. Its worked for me in the past.
